'04 DII or LR3
You can do your own top hat liner conversion for $3-4K. Buy one/install yourself for $6K or have someone do it for $7K. I went with option B and got a 3 year warranty and am pleased. I'm military and never know where I'll end up from one year to the next. Case in point...I'm moving to Turkey in June. Whatever I've got, I need to be able to work on it myself because I may be a ways from a competent mechanic. Nothing against LR3s, but with 1500 wires just controlling the suspension, it's a little out of my league. Most people are not in my situation, so the right car for you may be different (unless it's a Freelander!).
Replace the dryer on the compressor, if it's still got the hitachi style compressor. That's what causes the failures. The silica beads inside break apart and plug up the filters. Makes the compressor work too hard.
There is also updated software, a newer relay, and a valve and spring kit you can put in the hitachi compressors that will improve their reliability.
As far as the LCA bushings, when mine go bad again, I'll get some poly bushings from Lucky 8.
My air compressor went around 90k. LCA bushings around 80k. I replaced with the updated LR4 compressor and put polybush in the LCA.
The updated software is definitely a positive. The old update made the compressor run for long periods of time, causing it to heat up. The new update makes the compressor run more often, but for shorter periods of time, letting it cool down and extending the life.
nh9095
01-14-2019 12:36 AM
clandrovers
02-10-2013 10:46 PM
