wipersssss :(
Old Jan 29, 2012 | 06:11 PM
velija's Avatar
Default wipersssss :(
so did my head gasket now my front and rear wipers dont work, also when i try the spray the windshield and dont hear the pump but when i do the rear i rear the pump and water comes out
im thinking i fergot the connect something
checked all fuses and tried a different relay under hood
thanks
2002 disco 100k now with new gaskets
Old Jan 29, 2012 | 06:24 PM
Shouldn't have been anything related to the wipers that you would have to disconnect to do head gaskets.
Old Jan 29, 2012 | 06:43 PM
velija's Avatar
thanks Mike
i thought maybe i disconnected a plug while pulling everything apart and didnt connect it back
ill figure it out
let you guys know
thanks
Old Jan 29, 2012 | 11:01 PM
The front pump is separate circuit from the rear one. Plenty of fuses and relay under the hood and under the dash on these circuits. Were you swaping the fuel pump rela around, etc., while doing engine work?
Old Jan 29, 2012 | 11:21 PM
velija's Avatar
i possibly did, but i couldnt tell you for sure
would it matter
Old Jan 30, 2012 | 05:29 AM
Relay 7 and 3 would need to be present in the underhood box.
Old Jan 30, 2012 | 06:10 PM
velija's Avatar
thanks Buzz
7 is missing for some reason
getting me that much closer to getting it out on the road
