Bilstein Shock Install
Old Oct 7, 2009 | 10:59 PM
cranky's Avatar
Default Bilstein Shock Install?
Hi all,
I just got a set of front & rear Bilstein Shocks. I'm going ot install them on the weekend.
The rear shocks have been out and the top mount washers are installed different on both sides. One side is domed. Which way should they be?
Any other tips for a trouble free install?
thanks,
Nick.
________
CURVYQUEEN20
Old Oct 8, 2009 | 06:52 AM
cranky's Avatar
Anyone?
________
Web shows
Old Oct 8, 2009 | 07:55 AM
okdiscoguy's Avatar
domed side goes towards the inside. Doesn't really matter though. Be ready to jack it up high because trying to press the shock all the way down and install it real fast is a pain. They are difficult to compress..
Old Oct 8, 2009 | 03:51 PM
cranky's Avatar
Thanks,
yeah they take a bit to get moving!
I might try to tie them with some light twine before fitting. I can then fit them compressed and snip the twine after.
________
Naddia live
Old Oct 8, 2009 | 04:08 PM
lipadj46's Avatar
You don't need to compress the springs. Just put a good floor jack under the axle and jack it up undo the bolts, put the frame on jack stands and lower the floor jack and put your bottle jack on top of the axle and jack the axle down. This will allow you to get the springs out and in.
Old Oct 8, 2009 | 04:30 PM
cranky's Avatar
Just doing the shocks at this stage - springs might be next month. I know but that is all I have the budget for right now.
I will need to compress the Shock to get it mounted won't I?
________
NancySexy live
Old Oct 8, 2009 | 04:41 PM
lipadj46's Avatar
No the shocks are pretty easy they don't need to be compressed unless you have some super long travel shocks with a remote reservoir or something.
Old Oct 8, 2009 | 05:09 PM
cranky's Avatar
Just Standard issue, but i wasn't going to put it on stands. the rears can be done without jacking up the truck or removing the wheels, just need to compress the shock. I know this from an emergency road side refit!
the monroes that were on it could be compressed using one hand while lying under the truck. The Bilsteins are a diffferent story - needs my body weight behind it - so tying them up before hand might make it easier.
I don't have floor jacks etc. just the bottle from the truck - and it is on the way out (note to self: don't use for jacking up house).
I think i can do the fronts with the wheel on as well. undo lower mount, undo tower, remove through engine bay?
________
Vaporizer wiki
Old Oct 8, 2009 | 05:23 PM
lipadj46's Avatar
Yeah if you do them that way you will need to compress them a bit. Maybe invest in a floor jack one of these days. Harbor Freight and Sears have a good chinese 3 ton floor jack that is on sale all the time for $70. Get jack stands too if you plan on DIYing. That bottle jack can be scary at times.
Old Oct 8, 2009 | 06:32 PM
cranky's Avatar
LOL, I think I need to shop a bit more locally! (I'm in Australia)
Do the Bushings need to be greased before installing?
________
Kenizom
