free beer location
Old Feb 14, 2012 | 09:43 PM
parksy's Avatar
Default free beer location
ok so no beer , but if anyone can help with these codes " cams time out " and " can time levelling " . I got them read yesterday . its cos of m a nd s lights flashing . pleeeeeeeeeeeeeeeeeeease
Old Feb 15, 2012 | 07:25 AM
creepin's Avatar
Sorry I cant help.......But I like Beer...
Old Feb 15, 2012 | 07:55 AM
jafir's Avatar
CAN is the network that the different computers in the car talk to each other on. That sounds like the ECM and the transmission computer are having trouble hearing each other. Is your electrical system in good repair? How much voltage do you have with the engine off, and how much with the engine running?
Old Feb 15, 2012 | 10:33 AM
Again, what are the exact fault code numbers?
Old Feb 15, 2012 | 10:42 AM
drowssap's Avatar
i'm voting that it has to do with the dual batteries
Old Feb 15, 2012 | 10:55 AM
Good catch - dual battery hookup might, depending on wiring.....
Old Feb 15, 2012 | 10:46 PM
onewingman's Avatar
Default OBD....CODES? Ha
I just got an ULTRA GAUGE, I plug it in, or attempt to...the port is MIA...I find it, ( stuffed back in behind the bottom cover...not a good sign) it's missing the retainer, bezel whatever holds it in place, I'm not feelin' happy about this...
So, I plug the UG in and WaLaa, it starts scanning, it just never stops...I plug it into the Toy, WaLaa, it scans, it reads, so it's not the problem...
The Disco's throwing a CEL, can't read it...what I really WANT is COOLANT TEMP!
So, obviously, there is current at the port, but no other signals. Is this a "somewhat" "common" malady? The only other threads I found were pretty ancient and was solved by replacing the Alarm mod to accompany it's matching ECU from a wreaking yard...which had been swapped out due to h2o damage...However, that port was KIA until the alarm mod swap...
I just bought this thing a couple of mths back, who knows, the ECU could have been unilaterally swapped out...Any way to determine this? Also, if anyone has anyother insight into this, I would greatly appreciate your input.
Thanks
PS did the heads
Fivespddisco
Off Topic
Jan 26, 2010 06:18 PM
Fivespddisco
Off Topic
Jan 19, 2010 06:19 PM
heromanLSU
Jul 17, 2009 10:57 PM
salesup
Member Group And Special Buys
Jan 24, 2009 05:45 AM
Roveroh
Aug 7, 2008 09:42 AM
