braking system improvements?
Old Aug 29, 2008 | 01:00 AM
NiteTrain's Avatar
Default braking system improvements?
I've seen several people comment about the under performance of the discovery braking system for a vehicle it's weight, and I agree with them. Does anybody make an after market master cylinder or maybe the master cylinder from an RR would be an improvement?
Old Aug 29, 2008 | 08:44 AM
Darover's Avatar
Default RE: braking system improvements?
Braking is good for a Disco with stock size tires, it's when bigger tires are put on and its weight is augmented by tons of add-ons that braking becomes marginal. I will personally try this soon, but apparently braided stain less steel brake lines diminishes pressure lossthat takes place with stockexpanding rubber brake lines.
Old Aug 29, 2008 | 09:04 AM
Landzu's Avatar
ORIGINAL: Darover
I will personally try this soon, but apparently braided stain less steel brake lines diminishes pressure loss that takes place with stock expanding rubber brake lines.
Best money I spent,,, it does help more than you would think.
Old Aug 29, 2008 | 11:42 AM
NiteTrain's Avatar
I have stock tires and my braking still seems sluggish.
Old Aug 29, 2008 | 11:49 AM
When was the last time you flushed the brake fluid?
Old Aug 29, 2008 | 12:37 PM
NiteTrain's Avatar
ORIGINAL: Spike555
not sure when (if ever) it has been flushed..I've only put about 500 miles on my rover since buying it...After reading comments about the braking system I assumed moderate braking was normal for a rover...but flushing the system is a good idea I'll add that to my list.
Old Aug 29, 2008 | 04:40 PM
Disco2Guy's Avatar
Don't the '03-'04 D2's have better calipers? Not sure how much of an improvement there is though...
Old Aug 29, 2008 | 05:23 PM
NiteTrain's Avatar
more pistons per calipers gives you much better braking performace but 4 multi-piston calipers are really expensive..that's why I was wondering about upgrading master cylinder..it's usually much cheaper.
Old Aug 29, 2008 | 08:02 PM
sdsilvere38's Avatar
My brakes suck! everyone says to flush them on this forum. Did you guys try that yet, and if so did it make a difference?
Old Aug 29, 2008 | 08:05 PM
Yes flush them, it will make a differance. LR says every 24 months.
