Codes, idles rough and exhaust leak....
Old Oct 13, 2011 | 05:23 PM
jrm123180's Avatar
Default Codes, idles rough and exhaust leak....
So i'm still getting codes:
0135
0155
0154
0141
0161
Also, I notice that the car will idle rough...like the whole car vibrates, but NOT all the time, sometimes it will be idleing rough then all of a sudden STOP...COULD this be related to the codes above?
Also, Could the codes be related to the exhaust leak I just found. The leak is located at the "pipe to manifold". I just did an induction cleaning and discovered a little smoke coming from there and it was wet an "bubbling" while reving the motor, the bubbling stopped when I stopped reving the motor....
Thoughts????
Definetly gonna replace that gasket.
Old Oct 13, 2011 | 06:12 PM
How many miles on it, when was it last tuned along with 8 mm silicone plug wires and 4 02 sensors?
Old Oct 13, 2011 | 07:12 PM
jrm123180's Avatar
about 86k on the motor, 130k on the car.
Plugs, wires, air filter, have about 15k on them, O2 about 5k (second set under warranty to rule out the sensors).
Old Oct 13, 2011 | 07:50 PM
Well you are into 02's again and need to find out why. What octane gas are you using, any oil in the 02 connections and what brand of 02 are you using, with or without 4 wire plugs?
Old Oct 13, 2011 | 07:56 PM
jrm123180's Avatar
i'm using 93 octane, no oil in the connections, not sure the brand of sensors, BUT they are direct fit NOT splice in....
caneraiser
Oct 31, 2012 06:15 PM
Willie00d2
Mar 28, 2012 10:13 PM
EstorilM
Mar 4, 2011 08:54 AM
VikingDiesel
Feb 24, 2009 05:38 PM
sansime
Oct 16, 2006 01:54 AM
