Cracked Block
Cracked Block
Well, looks like I got a cracked block in my DII. The cooling system was pressurizing so I pulled the heads and the head gaskets looked OK. One of the pistons is much cleaner than the other so block is probably cracked behind that liner. Should I just put it back together and try the K&W block sealer?
The crack is behind the liner but the liner doesn't look like it moved. It is probably cheaper to just get a new block than re-sleeve this one. I will try a block sealer and see what happens, if it blows I'll just loose on gaskets and bolts. Has anybody tried chemical block sealers for this type of problem? I read somewhere that some blocks had this issue because of porous aluminum castings.
37chambers
10-28-2005 09:03 PM
