Are the D1 and D2 transmissions interchangeable??
Old 06-09-2010, 08:54 PM
Second2None's Avatar
Default Are the D1 and D2 transmissions interchangeable??
Reason I'm asking is because I found a decent D2 with a bad tranny and have a D1. I prefer the D2's a lot more and was wondering if the tranny's are exactly alike, if not: if it would be a direct swap anyway, and if it won't be a direct swap what would I need to do??
Please dont treat my 3rd post on here as if Im a newb, as some forums do lol. I do motor swaps on older bmw's for a job, so I'm decent with a wrench
Thanks in advance!
Old 06-09-2010, 09:00 PM
ljdiscovery's Avatar
no, the DI has mechanical linkage, etc. The DII is electronic. Phil
Old 06-09-2010, 11:23 PM
Are there actuators or something I can swap over / install or are the transmissions completely different??
Thx
Old 06-10-2010, 05:29 AM
d2luvr's Avatar
Can it be done? Probably. Will it light your dash up like Christmas? Of course. The DI has few electronics on it, while the DII is run completely by them.
Old 06-10-2010, 07:42 AM
No, it can not be done, they are completely different trannys.
Old 01-07-2016, 10:44 AM
mcabrera3's Avatar
Helo mike. What if the transmission comes from a 2003 land rover discovery and I'm going to put it in a 2003 4.6 laND rover discovery.
Old 01-07-2016, 02:04 PM
chubbs878's Avatar
Let me answer that for you, as it doesn't take a wealth of knowledge. FROM a 2003 will go into another 2003. its the same model
Old 01-07-2016, 02:06 PM
mcabrera3's Avatar
Thank you good sir!
Paul Grant
12-12-2012 04:33 PM
Paul Grant
12-05-2012 11:36 AM
zoso-
12-03-2012 02:08 AM
Paul Grant
03-30-2012 10:29 AM
tanakt
01-06-2007 07:04 PM
Quick Reply: Are the D1 and D2 transmissions interchangeable??
