Drivers Side tick 01 205k head gasket lifter or exhaust
Old Jan 12, 2012 | 03:47 PM
94svt50's Avatar
Originally Posted by roverbob
fixed 02 sensor issue- now it's throwing no codes at all and still makin the noise.
i put 5-50 oil in and when it's warm the noise is quieter
manual oil test showed 30+psi
i guess i have a bad tappet?
anyone know if a bad tappet would throw a misfire code?
That 30 psi is when? If that is hot at 2000rpm then you have an oil pump problem.
Old Jan 12, 2012 | 03:55 PM
But with 30 PSI - you'll have more noise soon. Spec for a D2 is above 10 PSI at idle, and 50 PSI at 2000 rpm warmed up. See the general data pages of the workshop manual.
Old Jan 12, 2012 | 08:03 PM
roverbob's Avatar
sorry that was 30 psi cold idle with fresh 10w-30 mobil one, i changed back to quaker state 5-50 and it's a lot quieter (didn't re-check pressure) now it's almost a squeaky noise... not consistant worst at low engine speed going up hill... still throwing no codes.
i have a 944 which were practically born to tap and this really sounds nothing like it... in fact i don't think i've ever heard a lifter tap whose severity was load dependant...
thanks for the help guys, i'm going to buy a used motor and rebuild it, hopefully this motor will make it till april-ish so i can swap that in when it's a bit warmer
Old Jan 12, 2012 | 08:05 PM
roverbob's Avatar
Originally Posted by jafir
It would have to be a VERY bad lifter to misfire.
thank you, i think i actually should have been asking about knock not misfire
Old Jan 13, 2012 | 11:50 AM
roverbob's Avatar
just to clarify further and i will likely upload a video so that when this is identified and solved it will be easier to reference for other people with ticking time bombs in their lrs the noise i am experiencing:
is engine speed dependent
seems to have quieted with thicker oil
is squeaky and metallic
is coming from the drivers side front of engine
is not there at idle or any engine speed with no load on engine
if you let off the gas it goes away
has a "less loud" rpm range centered around 3k
Old Feb 21, 2012 | 12:33 PM
roverbob's Avatar
Default Update
ok, attached is a picture of what i found taking the engine apart... def seems to be a head gasket... could also be a cylinder sleeve idk at this point
Attached Thumbnails Drivers Side tick 01 205k head gasket lifter or exhaust-02212012403.jpg
Old Feb 21, 2012 | 12:38 PM
roverbob's Avatar
upon removing the head gasket it almost looks like there is visable blowby from the seam for block/sleeve
can anyone confirm this is what i am seeing or is this just a bad head gasket?
Attached Thumbnails Drivers Side tick 01 205k head gasket lifter or exhaust-20120221_002.jpg   Drivers Side tick 01 205k head gasket lifter or exhaust-20120221_004.jpg
Old Feb 21, 2012 | 05:36 PM
94svt50's Avatar
thats a head gasket failure, nothing to do with the liner. Also, your ticking noise cause.
Old Feb 21, 2012 | 07:26 PM
roverbob's Avatar
thanks thats what it seemed like to me... just wanted to ask the community tho because i've never seen a hg fail like this but this is the first rover i've done a head job on
Old Feb 25, 2012 | 10:14 PM
Ad!'s Avatar
Ad!
Any updates roverbob? I have the same tick as you do so curious to see if you were able to fix it. Was the ticking any louder under the car?
