Erratic Gauges
Old 04-09-2007, 11:22 PM
Nitro96's Avatar
Default Erratic Gauges
This may have been covered before but I am new to the world of Discovery. I have purchased a rather nice 96 Discovery that has had it share of electrical Gremlins which I have cured except one. I have Intermittent Gauges, all of them Speedo, Tach, Fuel and Water Temp. Also some start ups I have warning lights other times I do not. Any suggestions on where to look to cure this problem?
Old 04-10-2007, 10:49 AM
Default RE: Erratic Gauges
Possible cracked circuit board???
Mike
Old 04-10-2007, 12:18 PM
Nitro96's Avatar
Thanks for the suggestion Mike,I will look into that. They work for a while then suddenly stop and start again. I was wondering if it could be a bad connection or ground on the fuse block mounted on the right front inner fender, or am I way off in that the gauges are not affected by this fuse block?
Rover5150
11-28-2007 09:57 AM
Rover5150
11-26-2007 06:09 PM
Fyko
Defender
07-06-2007 06:57 PM
GeoC
04-16-2007 12:35 PM
racdisco
01-30-2007 02:15 PM
Quick Reply: Erratic Gauges
