Extra cooling upgrades for the D2? (Towing and pulling grades)
I'd prefer to take my D2 on an upcoming camping adventure to the pacNW coast and plan on pulling the RPod travel trailer.
Unlike my LWB Classic or my wife's LR4/D4, my D2 continues to struggle with keeping engine temps down when pulling a grade or while towing. To save time on this thread, this isn't about diagnosing a poorly functioning cooling system, I've already done that. What I'd love opinions on, is how to upgrade my D2 for towing. So far I've found a couple of Australian sites where they talk about adding additional transmission and oil coolers, but no links to which ones or how they were installed.
i'm also curious as to whether anyone has experience with the Allisport radiator? Allisport claims a 30% improvement in cooling efficiency over the stock radiator.
i'm very interested in US based folks who have tackled this problem. Bigger radiator? Additional/bigger transmission cooler?
cheers!
cheers!
The only other options I would say besides what abran posted is electric fans, inline thermostat mod, and water wetter. The inline mod will help the cooling system run lower but you being in the pacnorwest might need a radiator muff(yea I said muff lmao). The electric fan will increase air flow draw through the radiator and I haven't seen anything on radiators BC believe me I'm sure they would make a fortune off of the member of this forum, myself included, if it were factual.
I run a factory 180 degree thermostat and I use the water wetter by royal purple and I pull a lifted golf cart with tailgating supplies every weekend during football season( about 200 miles round trip) and also pull it to the hunting club depending on the season, anywhere from 300-600 miles round trip and never had any issues with the cooling system overheating
mans just for FYI l, yours is properly equipped. All front covers on the 99.5-04 have the ports for them. The only difference is that yours are plugged by 2 brass plugs and they are easily accessible.
My problem only occurs while climbing grades. It occurs regardless of which stat I run, cooling system can't keep up.
i actually do have an inline stat already, hood louvers (engine bay heat was melting wiring under hood), ceramic coated headers and an oil cooler (purchased a trans cooler from Abran)
Maybe the way I should have phrased the question is to ask if anyone has upgraded their cooling system for heavy towing. The Allisport aluminium rad comes with fans pre installed and boasts 30% better cooling capacity but at close to $1k I'd prefer to hear what the community has done.
on another note. Anyone got a source for D2 oil cooler lines? Can't find new ones anywhere and the ones I got with the trans cooler are leaking.
I may try the Hayden radiator mister and see if that alleviates the problem. If it does, then it may be time to bite the bullet and go with the Allisport.
whats your definition of overheating and how is your truck built? (4.6? , wheels/tires?, rack? Bumpers? Sliders?)
