Got a P0440 What exactly needs to be repaired???
Old Jul 12, 2011 | 11:18 AM
Adsan1280's Avatar
Default Got a P0440 What exactly needs to be repaired???
2002 Land Rover Disco II
Got a P0440 What exactly needs to be repaired??? Is it something I can easily fix myself? Or do I have to take to a mechanic?
Taking instructions and suggestions!! Thanks.
Old Jul 12, 2011 | 11:42 AM
That is a opened fault indication the evap system has malfunctioned. If you are not mechanical a mechanic is in order, just not the dealer.
Old Jul 12, 2011 | 11:48 AM
dgi 07's Avatar
Leaking purge valve. Highly doubtful you have a smoke machine to properly diagnose if it is the purge valve. Recommend taking it to a mechanic with one.
Old Jul 12, 2011 | 12:14 PM
Adsan1280's Avatar
Thanks guys - now does that fault code have anything to do with the scratchy acceleration sound? the engine is somewhat quite at idle, however when I accelerate it make the said sound and chokes up a bit during cruising mode.
Old Jul 12, 2011 | 12:21 PM
sloan74's Avatar
Land Rover Charcoal / Carbon Cannister Purge Valve (Valve Only - Hoses Not Included) & Other Parts For Rovers at Atlantic British
Let the mechanic diagnose then you can order and install the part yourself (if that is what it is). Hopefully it's the purge and not the CVS unit. That part is a little more $.
Old Jul 12, 2011 | 02:23 PM
Adsan1280's Avatar
Thanks all for the info - I will check it out this weekend and keep you posted on the outcome.
Old Jul 12, 2011 | 06:00 PM
bosshogt's Avatar
I replaced the purge valve on mine and used the worm drive hose clamps. I still get the CEL light about once a month with the p0440 code. I have heard replacing the O ring on the top of the fuel pump has worked for folks. I have been too lazy to get mine smoke tested as I have not seen any drop in performance or MPG.
Old Jul 13, 2011 | 08:26 AM
Adsan1280's Avatar
Thanks for the info bosshogt. I'm gonna have to get it smoke tested to avoid the guessing game as it has been somewhat frustrating and I don't want to end up spending money where its not needed. Def appreciate the input.
Altide8
Oct 27, 2014 09:16 AM
Willie00d2
Sep 14, 2014 10:44 PM
Tracie Sereno Kindle
Apr 24, 2012 08:13 PM
tsuami1
Sep 27, 2007 04:34 PM
kfordric
Sep 15, 2005 04:15 PM
