I have to replace the headgaskets-argh!
Today with it 105 degrees outside, I noticed that coolant was slightly bubbling out of the front of the left head where it meets the block. So, I will be replacing the head gaskets. I searched the archives and did not find the answer to this question.
Here is my parts list, what am I missing?
Headasket set
Headbolts
Valve cover gaskets
Valley pan gaskets
Intake manifold gasket
Exhaust gaskets
Gasket sealer
Thermostat
Coolant
Radiator hoses
Fan Belt
Headasket set
Headbolts
Valve cover gaskets
Valley pan gaskets
Exhaust gaskets
Gasket sealer
Thermostat
Coolant
Radiator hoses
Fan Belt
I just did mine here is what I got:
- Head gasket kit from Atlantic British
- Cylinder Head bolts
- Thermostat
- Belt (if needed)
- 2 hoses that needed replacement (rest were fine)
- Tube black APV gasket sealer
- Coolant
- Power steering fluid
- Rave CD or Shop Manual
It's not that bad just take your time and keep track of your bolts.
- Thermostat
- Belt (if needed)
- Coolant
Good luck! Let us know if you need help. Like I said I just got done with mine so it is fresh in my mind. I was planning on doing a write up but it's a pretty intensive job and I decided to concentrate on doing it right instead of a write-up as the procedure is already in the shop manual with pictures. If you don't have them already here are some tools you will find indispensable (all tools available from Harbor Freight):
- 8mm 12 point socket to get off the rocker cover bolts. 6 point socket will not work
- A full wobble extension set ($15)
- A full metric impact driver set ($35), you will break regular sockets on this job
- 3 piece impact driver extension set ($15)
- A few good breaker bars of different length, one at least 32" to get off the head bolts.
- Long jointed extended ratchet to reach the hard to reach bolts ($20)
- Metric damaged bolt extractor set saved my bacon on a bad head gasket bolt ($20)
This is of course in addition to the normal stuff like a 150 lb torque wrench etc. I apologize if you already knew this, I did not have these and it took a couple trips to get all the tools.
Edit: Just saw you have a DI so not sure if the rocker cover bolts are the same size.
DI's have the same 8mm 12pt bolts on the valve covers...
