Alarm problems with Disco II
Bought disco II from repo auction and replaced damaged ignition with one from another vehicle that was being parted out. Vehicle comes to life electrically but will not start. Jumping starter relay allows vehicle to run for 1-2 seconds. Horn is honking and flashers flashing. Led on dash flashes but is not steady so I'm assuming it is not immobilized. I have seen many posts similar to this but could not find exact answer to my problem. I didn't get any paperwork with vehicle so no EKA code. Looking forward to getting it running and racing my favorite wife around our property in her LR3!!!
Inertia switch pushed but no click. I assume it did not reset. Tried door locks as you said but still no luck. The alarm appears to set (rapid blinking of led for about 10 sec) when doors are locked. When door unlocks led blinks quickly with about a 2 sec pause in between blinks. Flashers flash and horn sounds when drivers door is opened. Tried to start in neutral. No luck. Thanks in advance for your help. I've seen your replies in numerous posts--very good of you to offer your expertise.
Also, forgot to mention the key fobs do not lock/unlock doors. Does this have some effect??
I have been reading all the info I can on this issue and the alarm does seem to set when door is locked (rapid flash of led for 10 sec) but does not seem to disarm. Could really use some help. Tried the methods I have seen listed but the flashers start flashing as soon as drivers door is opened or if i sit in vehicle and lock and unlock with dash button the alarm starts as soon as key is put in ignition. I must be close--just need a response from someone who knows how to overcome this situation. Thanks
Unit may have sat without battery for so long that sync was lost between the ECU and BCU, requires a shop with proper computer to reset. Would be better if fobs were working, perhaps battery dead in them? BCU controls alarm and inhibits engine running, has to exchange coded data with ECU. You could also have a bad door lock switch that controls the alarm.
That makes lots of sense. I have another thought. I ended up purchasing the other disco 2 that was being parted out that I salvaged the ignition and key from. I put a battery in the car (the parts car) and the fob locks/unlocks doors, the engine turns over, fuel spits out (the heads and intake are all missing from this one) and everything seems to work as normal. Could I change the bcu from the parts car to the one I am trying to get running??? What are your thoughts on that??
The alarm flashes rapidly for 10 sec when door locks. On and off when door unlocks. How hard is it to change ecu. Don't care about odo really. If the vehicle would run I would be fine with everything else. Just really going to use it on short trips into town and goofing off on our property/woods/creek. Where is ecu located and what does it look like??? Before doing that I will try the 1515 again. Of course the door key is now different that the ignition key because of ignition swap. Am i on the right track with changing bcu/ecu or should I try to fix the problem. Don't want to have to tow to the dealer that is almost 1 hour away and pay their prices. We just don't need the vehicle to be perfect--just running. My wife considers her LR3 "her perfect vehicle"!!
Also...replaced batteries in fobs..they light up correctly. Thanks for your help with this. It is greatly appreciated.
When I replaced my ECM and BCU, I had a specific code for a communications problem between the two computers. The symptoms of loosing the sync are that it will start and then immediately die.
Since your LED isn't turning off, you probably cannot even get it to crank with the key, let alone start. Sometimes the security system gets all angry if the battery gets low, and will not let you disarm. Let your battery fully charge, with all the doors closed (maybe the windows down, so you don't get locked out) and just walk away. Come back after half an hour or so after the batter is charged, and unlock the door with the door with the key. Hopefully the LED will turn off and you can start the car. If not, try the EKA.
