new hub, seal, or just get a jeep?
#21
OP...if all you're looking at is a leaky hub and cash is an issue, pay the $1.00 and just replace the hub seal. If you had a failing hub either you or the car/abs would know it. You don't need to remove the big axle nut to change the hub seal. Pull the bolts and slide the entire hub and axle out. I certainly wouldn't go around changing hubs as part of a PM routine.
#22
#23
Axle nut torque
I posted the axle nut torque because on my driver rear wheel bearing one day I smelled gear oil. So I had the O-rings already. It was a 30 minute job to pull the hub. I cleaned everything, make sure the Oring couldn't get pinched and it still leaked the next day. I read through the RAVE manual and looking at the cutaway diagram I took the axle nut off (was already loose was able to remove with a 3/8" ratchet) I put a bead of black RTV sealant where the axle shaft met the bearing and installed a new Axle nut. Torqued to 360ft lbs. No more leaks.
#24
You will need a suitable diagnostic tool like a Nonocom or Hawkeye and there are others that test down ABS systems and identify the exact faults. General diag tools don't give specific causes of the problems.
#25
#26
Thanks for the info. I have the ultra gauge and think that thing is awesome. It let me know last night I have a 300 and 304 code. Before it would have worried me but now that it is the 3rd vehicle, it looks like I get a weekend of tinkering soon. The only reason I can't spend too much on the rover is thanks to this texas rain we have found some leaky doors and windows, so wife and I agreed to save for that.
