new hub, seal, or just get a jeep?
Old May 24, 2015 | 04:04 PM
stuckntx's Avatar
Default new hub, seal, or just get a jeep?
http://1drv.ms/1ITwHaG
As you can see I have what appears to be a hub leaking. So do I replace the hub or seal? I am also hoping this takes care of my good friends the three amigos.
Old May 24, 2015 | 05:37 PM
dgi 07's Avatar
Get a Jeep.
Old May 24, 2015 | 09:16 PM
stuckntx's Avatar
That's what my wife says, but I am leaning toward the $0.95 seal.
Old May 24, 2015 | 11:27 PM
dgi 07's Avatar
Lol.....seal it is then.
And you still have some coin left over for some beers and a bottle of jack.
Old May 25, 2015 | 03:08 PM
Alex_M's Avatar
Is it your DD? Get a jeep. Is it a toy? Fix it and move on. I'm in the process of looking for a TJ wrangler to daily drive and let the Disco be a weekend toy.
Old May 25, 2015 | 03:43 PM
stuckntx's Avatar
It was my daily driver but now is my toy. Bought my wife a vehicle last weekend and I got her Toyota camry. My jeep comment is all in fun. I will probably do the seal but my only concern is my three amigos. Did the shuttle valve replacement and hoping that fixes it. The abs port in the hub was covered in oil and wonder if that would cause the three amigos.
Old May 25, 2015 | 06:49 PM
OffroadFrance's Avatar
Hard to tell from the photos whether front or rear hub but about the same amount of work whatever. The rear is an O ring and the front is a seal but as a guess the front is slightly more difficult. It's about a 3 hour job and a few cents for front or rear seals. Also check your axle breathers aren't blocked otherwise you're wasting your time.
Old May 25, 2015 | 06:51 PM
Merlin390's Avatar
In mine I had to retorque the axle but to something in the 300 ft lb range to get the rear axle sealed.
Old May 25, 2015 | 08:59 PM
stuckntx's Avatar
Sorry, I guess I did not give the location. It is the rear passenger. Does not appear to be a difficult job.
Old May 25, 2015 | 09:00 PM
stuckntx's Avatar
300 ft lbs? I don't think most wrenches go that high. I will keep this know mind.
