New owner.. 04 Disco II
Old Jul 24, 2007 | 09:44 AM
Velo_Rover's Avatar
Default New owner.. 04 Disco II
Wanted to stop by and make my first post a "Hi how you doin'" post and not a "Help, everything is wrong with my Disco" post. I have spent the last couple hours running through the threads, finding answers and hints that I would not have found elswhere. Thanks!
Obviously there had to have been a reason for my stopping by. "If it doesn't leak, it isn't a Rover" is true in my situation but there are a few things that I have gleemed off previous posts that I'll try when I get home. Mainly after it rains I have a wet floor on the passenger side running from front to back. I'm going to check the windshield/screen, blow out the drains and then check a few things under the hood.
I appreciate everyones trial, error and knowledge!
-bps-
Old Jul 24, 2007 | 10:49 AM
Default RE: New owner.. 04 Disco II
Sounds like your front sun roof drain tube is either plugged or has become disconnected.
Mike
Old Jul 24, 2007 | 04:03 PM
IanHand's Avatar
Not sure if you can tell, but has the windshield been replaced recently? If so the installer could have easily gummed up the job. Believe it or not I had my windshield replaced 6 times because of a bad install job. We had a monsoon type storm when the problem first surfaced and it ended up ruining the headliner (a $1,100.00 repair the glass company had to pay for through Landrover)! Apparently my issue is pretty rare but I think the process of replacing a windshield in a Disco is a pretty harowing affair. If it was replaced I would keep my ordeal in mind! Good luck!
Run33
May 11, 2015 09:43 PM
kayak74
Jan 23, 2013 07:13 AM
jswift
Jun 21, 2011 12:12 PM
MuddMouth
Sep 30, 2010 10:30 PM
desh72
May 5, 2007 12:03 AM
