New steering damper
Old Oct 30, 2008 | 12:39 AM
Elhoff's Avatar
Default New steering damper
I got my shipment of OME shocks and springs on monday. Can't actually change the springs and shocks until I get the rear airbags from Arnott and the SLS spacers from RTE. But I decided I could go ahead and install the new steering damper. After a trip to the store for an 18mm socket, the job took about 10 minutes! From a quick test drive it seems to have made a significant improvement in my wandering around on the road problem. Wish i'd done it a few months ago. Now I just need those last few parts and a weekend of clear weather :-)
Old Oct 30, 2008 | 07:29 AM
Landzu's Avatar
Default RE: New steering damper
Good for you,,its nice when something so small helps so much.
Old Oct 30, 2008 | 09:43 AM
okdiscoguy's Avatar
I did the same thing a year ago. Found one on Craigslist for $40. Can't believe I even thought about it. Really noticable improvement for not much money or time.....
Old Oct 30, 2008 | 02:44 PM
pit_ownr's Avatar
well i have had a shaking problem and comes to find out it was the steering damper. well i ended up paying 70 from bap geon. nobody else had one. well hopefully it takes me only ten min. is there any tricks or anything you would recomend?
Old Oct 31, 2008 | 12:24 AM
Elhoff's Avatar
pit_ownr
I did not even have to jack up the front end! I found that an 18" breaker bar was very helpful in getting the nuts loose. Not sure if it matters, but I arranged the breaker bar perpendicular to the tie rod, so I didn't put too much twisting torque on the tie rod. BTW, they are Ny-loc nuts, so will be stiff all the way off. The shop manual calls for 92 ft-lb torque when putting them back on.
Elliot
thehun
Mar 10, 2011 08:11 AM
N.Franklin
Nov 13, 2007 08:06 PM
Fonzie
Nov 1, 2007 08:55 PM
RedElephant
Jun 3, 2007 07:31 AM
anonimaus
Oct 29, 2005 06:22 PM
