Whats needed?
Old Jan 15, 2012 | 01:39 PM
Street Wolf's Avatar
Arrow Whats needed?
What all do I need to order for a complete transfer case gasket/seal overhaul? I only have one leak, but if I'm going to pull the case I'm going to replace everything at once.
Old Jan 15, 2012 | 02:59 PM
jafir's Avatar
if it's just leaks:
Ashcroft Transmissions - Full Gasket and seal kit to fit all LT 230 Transfer boxes.
Old Jan 15, 2012 | 03:06 PM
jafir's Avatar
Also, there is a seal kit for the D1 with part number RTC3890, I'm not sure why it wouldn't work on a D2, unless it's the output flanges are different sizes... I know the front drive shaft flange is different on a D1 and D2.
But it's only $9, so if you needed a couple of extra seals, you could probably go that way and buy them separately.
Land Rover parts, spares, Land Rover accessories - Search results for RTC3890
Old Jan 15, 2012 | 06:58 PM
So basically what you're saying is I should buy this
..and hope the gaskets and such all work on the DII transfer case, and also order one of these
Output Seal for Land Rover Discovery 2 V8 - FTC4939 - 2000
and one of these, right?
Mainshaft Seal for Land Rover Discovery 2 V8 - ICV100000 - 2000
Old Jan 16, 2012 | 01:16 PM
jafir's Avatar
Just based on the applications listed, I bet both of those seals are in the kit.
Old Jan 16, 2012 | 01:26 PM
Eh, just ordered a front/rear output seal from RovahFarm. No one seems to actually have the DiscoveryI reseal kit in stock anyways. :\
Old Jan 22, 2012 | 12:05 AM
Would anyone happen to know of a cross-reference number for a more generic and locally available seal to replace the oil seal for the input shaft on the transfer case?
Evan Wiley
Dec 31, 2012 03:43 PM
oilspotLR
Apr 8, 2012 10:08 AM
Randy Lover
Off Topic
Jan 12, 2006 02:52 PM
angelinajolie
Dec 21, 2005 10:31 PM
madisco2
Jan 28, 2005 12:46 PM
