Odd issue after replacing shuttle valves
Old Feb 24, 2013 | 08:03 PM
NiteTrain's Avatar
Default Odd issue after replacing shuttle valves
I replaced the shuttle valves about a month ago. After replacing them the 3 amigos were gone..for a while. Then they came back. I have discovered when starting the rover if I pause the ignition switch in the number 2 position for a few seconds before starting the 3 amigos do not come on. However if I start the rover without pausing then the 3 amigos show up. Has anybody else encountered this issue after replacing the shuttle valves?
Old Feb 25, 2013 | 06:46 AM
drowssap's Avatar
what code were you getting before and what code are you getting now?
Old Feb 25, 2013 | 09:55 AM
NiteTrain's Avatar
I was getting a faulty shuttle valve code before replacing them. I'm not sure what the code is now. I need to go get them checked.
jamieb
Jun 27, 2014 08:12 AM
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Jan 16, 2012 07:02 PM
aarongregor
Nov 14, 2011 08:31 PM
ruffram
Sep 1, 2011 08:15 PM
