Rough Idle
Rough Idle
My service engine soon light came on the other day and my truck now has a very rough idle. I took it to my mechanic and he got 2 codes. P0150 and P0174. I always run good premium gas and just replaced the plugs and wires about 2 month ago. Bosch Plugs. Land Rover Wires. My truck is a 2002 Disco II with 71,000 miles. Any help would be appreciated.
RE: Rough Idle
theyre 22mm, easy to do, but the connectors can be a pain to get off and back on if youre on your back... however it might not be the sensors... since you also have the lean code theres a good chance that your o2 code is just a plausibility fault and youre actually looking at a vacuum leak on your rh cylinder bank. you might be wasting a good amount of money on some sensors if thats not your issue. try replacing the upstream sensor on the rh side, if it fixes it its your issue then go ahead for the rest. but check your enigne for air leaks. look at right where your rubber breather tube goes on to your upper intake on the rh side(pass side) theres a little nipple, you should either have a cap on it or a plastic vacuum harness that goes to it. also a large exhaust leak can cause this, and in the end spark plugs or arcing wires that are causing your fuel to not burn all the way will give you the same lean code. personally i would be looking more towards the lean code then the o2 code
