Running Hot
Old 06-22-2007, 04:31 PM
disco97's Avatar
6th Gear
Default Running Hot
My 97 Disco runs hot at slow speeds but then cools down to normal once hit speeds above 40 mph. Had radiator rodded, new water pump, belts, hoses. Still overheats. Dosen't matter if the A/C is on or not. Any thoughts on why it keeps on overheating.
Thanks,
Bub
Old 06-22-2007, 04:54 PM
Landzu's Avatar
Default RE: Running Hot
I would check your fan clutch.
Also the small AC fans may not be working.
Old 06-22-2007, 05:25 PM
okdiscoguy's Avatar
X2 on that.
Old 06-22-2007, 05:45 PM
98roverguy's Avatar
Fan clutch sounds about right. Consider your thermostat as well.
Old 06-22-2007, 07:17 PM
I would also suggest you don't drive it any more till you find the problem or you be looking for an engine.
Mike
Old 06-23-2007, 08:19 AM
disco97's Avatar
6th Gear
Ok guyss, Thanks I'll check the fan clutch and thermostat.
Bub
Old 06-23-2007, 09:42 AM
How about coolant leaks, have you been needing to add some prior to the radiator repair? You might want to do a coolant pressure test and a chemical block test to rull out head gaskets.
Mike
Old 06-23-2007, 10:20 AM
disco97's Avatar
6th Gear
Noticed that one of the small electric fans don't come on. Could this be enough with just one to overheat???
Old 06-24-2007, 01:02 PM
disco97's Avatar
6th Gear
Anyone?
Old 06-25-2007, 09:42 AM
Smorgan2004's Avatar
Both of my fans wern't working, but the only time it wouldget hotwas when I was sittingin traffic or a drive through. I would put it in neutral and hit the gas and that would cool it down. Now the fans are replaced and no morehot engine.. mine would go about 3/4 of the way up the gauge but never in the red. Good luck Scott
Pik
03-27-2013 08:00 PM
94svt50
07-08-2012 03:31 PM
LRScott
13
04-07-2010 02:26 AM
twmj1953
09-29-2009 09:49 PM
dgstringfield
07-12-2006 12:17 AM
Quick Reply: Running Hot
