Steering centralizing bolt
Update: So I went to my local hardware store and matched up a bolt to my new gear box. The bolt is an 8mm, 1.25 pitch (M8/125) bolt. I bought both a 70mm and 80mm length bolt, b/c I'm not sure which length is needed to lock the drop arm to the box, but when I replace the gear box this weekend, I'll let you know which bolt is the better fit.
