Shop Manual
Old May 1, 2009 | 08:49 PM
girouardrover's Avatar
Smile Shop Manual
Need a little help. I was wondering how I could get a copy of the shop manual for my 2003 Disc II.
I saw many posts on the forum refering to "RAVE", rave Cd, etc.
Many posts have links. Some talk about a "rave cd" and how it doesn't work. Some talk about a PDF. I attempted to download a Cd and got an "iso" file. This didn't work.
I attempted to download a PDF and this came up with a "file error".
At this point I'm totally lost.
Not sure what is what or what works.
Any help would be greatly appreciated.
Thanks
Old May 1, 2009 | 08:53 PM
Disco Fuego's Avatar
AK has the following link in his signature: http://www.landroverresource.com/
You can download the RAVE manual there.
Good Luck!
Old May 2, 2009 | 07:43 AM
stu44mag's Avatar
You will need to burn the .iso file onto a CD. After you burn it, then you will be able to open the file. You can not run an iso file directly. If you have a Windows XP machine go the "start" menu, go to "all programs", find "sonic", and open the "copy module". Follow the direction and you should be good to go.
Old May 2, 2009 | 08:35 AM
AK Rover's Avatar
Land Rover Resource is ready to go after you download. No need to burn to a CD or anything else.
Old May 2, 2009 | 04:18 PM
wow. the link to landroverresource.com worked.
thanks for sorting this out for me
Old May 31, 2009 | 05:50 PM
graham's Avatar
I downloaded from both sources, and they both get broken down into a thousand files which seem to be fragments of the software as a whole.
Is this because I had to download the whole 590 MB manual off landroverresource.com? It looked like that was the only way to get the manual for the '97 Disco....is the 95-96 manual okay for the '97?
Old May 31, 2009 | 06:27 PM
graham's Avatar
rovertex
Nov 6, 2008 01:00 PM
mrjcrew
Apr 29, 2008 09:21 PM
msturdy
Jul 24, 2007 03:16 PM
Erik
Jun 13, 2007 08:54 AM
agarabaghi
Jul 27, 2005 09:42 PM
