Timing chain on a 2004 Discovery - life span
There is NO replacement interval o a timing CHAIN, they last the life of the engine, you are thinking of a timing BELT, which needs to be replaced every 60,000 miles.
You have a timing CHAIN.
http://www.roverparts.com/Parts/ERC7929.cfm
Leave it alone.
Leave it alone.
I've heard of a few instances of people (myself included) having to do timing cover gaskets and they noticed a fair amount of deflection (play in the chain) whilst having everything exposed. I didn't bother even looking to see if the RAVE CD had the specifications posted...I just replaced the chain while I was in there. But as others have already stated, you don't typically replace the chain, I'm not even sure how much of a benefit replacing a chain that has deflection in it is going to do on a motor with say 80K on it...Considering you've got cam wear, lifter/pushrod wear etc. It might tighten up the timing a little and benefit you some...
We Disco owners can be **** though, especially with some of these jobs...if you ever have to do a timing cover because of a coolant leak (and you're not a professional mechanic), you're going to replace everything you possibly can while you're in there...waterpump, timing chain, thermostat, belts, hoses etc...
Hello everyone, I am a new 1994 discovery owner. I live in the West Indies and have put my (new to me) vehicle in for service etc. The repairer assured me that there is no timing belt to change and that there is some kind of gear system fitted to the cam shaft. Does this make sense to the Land Rover experts out there?
Also (hate to be a pain in the butt) but need some advice about the front parking lights. Both bulb holders have deteriorated and do not work (these are the small ones which clip into the back of the headlamp. I cannot get them here - do any of you know of anything I can use as a conversion?
Here is a close up pic of the timing chain and gears.
IMAG0209 | Flickr - Photo Sharing!
The top gear is on the cam shaft and the gear closest to the camera is the one that turns the distributor.
The bottom gear is the crank shaft, the chain ties the crank shaft and the cam shaft together.
https://landroverforums.com/forum/di...-instal-43603/
That is correct, if you have the V8 there is NO timing belt.
The bottom gear is the crank shaft, the chain ties the crank shaft and the cam shaft together.++++
Thank you for that information - I am not used to this and apologies for not giving more detailed information, the engine for which the repairer claims does not use a timing belt is a 2.5 diesel. According to the manual I have it has a belt but the repairer assures me twice that it does not. Are there any 2.5 diesels without belt or do I need a different vehicle repairer?
Spike even used my pictures!
