vacuum cleaner under the engine?
Old 03-15-2009, 10:45 AM
herblatham's Avatar
Default vacuum cleaner under the engine?
I've started to get this noise under the hood, that sounds like a vacuum cleaner when ever i accelerate, I had the mechanic check it out, he says it's the water pump, and that it needed to be replaced. I don't believe he was correct, My engine isn't overheating, and there are no leaks. Someone else said that they think it's my alternator. It only makes the noise when i accelerate.
98 disco
136000
Old 03-15-2009, 07:25 PM
Remove your belt and then spin things buy hand, do they make any noise?
With the belt off start the truck and then rev the engine over 1500 rpm a couple of times, does it still make the noise?
I must add, DO NOT let the truck over heat while you are doing this.
Only run it for a few minutes and with the heater on.
Colorado David
09-02-2014 07:42 AM
rezzrover
05-07-2013 06:02 PM
rekogniz1
11-05-2009 08:15 PM
targotsi
01-31-2009 06:12 PM
DeepBlueWater
10-15-2007 07:38 PM
Quick Reply: vacuum cleaner under the engine?
