Vibration at 30-40 MPH
Old Jan 24, 2012 | 12:42 PM
miamihi420's Avatar
Default Vibration at 30-40 MPH
Hello all,
I have a 2001 Land Discovery that is experiencing vibrations as I accelerate between 30-45 mph. I changed front and rear shocks, I got 4 new tires and balanced them and I did alignment at Sears. But.... I still have that vibration. Someone suggested it could be the U joints or the driveshaft. Any suggestions? When I let off the accelerator the vibration stops but when I gas again it vibrates. Once it passes 50 its fine and below 30 not very noticeable.
Old Jan 24, 2012 | 12:55 PM
humroot's Avatar
Have you rebuilt the front driveshaft with greaseable u-joints? If not, stop driving it and get it done asap. If the front driveshaft goes, it will most likely punch a hole in your tranny as well.
Old Jan 24, 2012 | 06:45 PM
jeffh's Avatar
besides the front prop shaft... you should do regardless..however this sounds more like the roto-flex coupler. it is in the rear between the rear propshaft and the rear diff.
Old Jan 24, 2012 | 09:35 PM
grandkodiak's Avatar
Replace them both. ASAP and welcome to the wonderful world of being owned by a Discovery
Old Jan 24, 2012 | 09:37 PM
I mean Discovery ownership.
Old Jan 24, 2012 | 09:52 PM
bullcrew's Avatar
As said make sure if it hasn't been rebuilt to do that to the front drive shaft, I did mine and have a vibration still at 35 and 71mph but I know my drive shaft needs to be balanced the weight is missing.
If after that it still vibrates I'm doing rear flex disc and then check prop shaft.
Good luck but as stated Do Make sure your front drive shaft has been rebuilt with greasable fittings on joint,.
dirtbag
Jun 3, 2015 07:51 AM
ljdiscovery
Nov 29, 2010 11:32 AM
MuddMouth
Oct 11, 2010 09:13 AM
samue23
Nov 23, 2007 12:01 PM
garywinans
Jul 27, 2007 08:07 AM
