Whoops
DiscoBuckeye (04-30-2016)
been there, done that! Except I broke BOTH. DON'T break the other one, it's $40 (the red brake servo).
The one you broke, get an air compressor fitting with the same threads. I found one after trial and error trying this and that. Get it done because it affects vacuum. Basically the air compressor fittings are in the Home Depot, Tractor Supply, etc. Just unscrew the nipple, take it in to match as closely as possible with a METAL one. $3 or $4 max.
Not sure the size, maybe 3/8. Bring your old piece in to match, Just unscrew it out.
This is what you need. The part with threads screws in, the black hose clamps on the smooth end.
get the old one out and bring it with you. get the old one out, bring it with you. get the old one out, bring it with you. :-)
