Engine & Internal Chat about beefing up your engine's insides here.
Freelander
Old May 21, 2005 | 09:48 PM
Claree's Avatar
Default Freelander
Do anyone know if there are mod parts out there for the freelander?
Old May 22, 2005 | 02:20 AM
05LandRover's Avatar
Default RE: Freelander
what kind you got? i.e. motor, transmission, etc year
Old May 23, 2005 | 01:27 PM
mikemeyer0's Avatar
what kind of mods you looking for. I built a cold air induction for mine, installed an eletric fan, removed rear muffler and replaced front muffler with a flowmaster, Installed some MSD wires, got rid of running boards and rear step to lighten it up a bit.
Old May 23, 2005 | 08:17 PM
Claree's Avatar
i just find my freelander a little slow in pick up...is there anything i can change to make it faster? ie. changing the transmission maybe? im not sure...~
Old May 24, 2005 | 01:19 AM
put a 175 shot on it, caution: internals will likely be blown. check out bassani or maybe borla, i think they might make a cat back exhaust for it
Old May 24, 2005 | 08:46 PM
Claree's Avatar
alrite i'll look into that...does your car have the same problem? or am i just overly paranoid..and it's really normal for my car to do that since its a 4x4?
Old May 25, 2005 | 01:23 AM
what the problem is a 2.5 liter v6. if it had, oh, lets say a 5.0 H.O., that would be both impressive and fast. one of my other vehicles is a 94 mustang GT convertible, mint condition, all stock, all that showroom quality BS, well it is quick. if you want speed, get the freelander out in the country any hit up like 110, that is what i do. the mustang, more like 135 in no time. freelander even at top end takes a while to get to speed.
Old May 25, 2005 | 02:18 PM
mikemeyer0's Avatar
ORIGINAL: Claree
transmission is prolly out of the question, don't think there is just something you can replace it with, also it won't give you really any better performance, look into cat-back exhaust, induction, MAF, your truck is really not a hot rod so there are not going to be very many hop up parts. IF you wanna pick up some low end look into some gears, front and rear, its a big job but it will do it.
Old May 25, 2005 | 08:22 PM
about the front gears, that might be kinda tough on a transaxle, rear would be like any other vehicle. but i don't know transmissions as good as i do other stuff, still learning
Old May 25, 2005 | 08:58 PM
mikemeyer0's Avatar
you can do gears in front and rear but it will be a big and expensive task. try enginge mods to save money, and if your not a big time off roader i would not mess with the running gear.
