Engine & Internal Chat about beefing up your engine's insides here.
transmission fluid leak
Old May 23, 2011 | 01:44 PM
dacsey's Avatar
Default transmission fluid leak
Greetings all,
I am brand spanking new to the forum and to Land Rover so please excuse me for the lack knowledge or incorrect term usage.
I have a 1999 Range Rover, and have what I assume to be a transmission fluid leak. I originally thought it was a coolant leak, after looking for the leak it appears that it is coming out of the radiator. After trapping the fluid I now realize it is pink. Definately not the color of the coolant. Does the transmission fluid go through the radiator to cool it? Where might I start to troubleshoot a transmission fluid leak? Where do I find the cap to check the fluid? Is it and enclosed system, can I even get access to the trasmission lines for a somewhat easy inspection? Any help is greatly appreciated and Thank you!
Old May 25, 2011 | 07:45 AM
Don't take this personaly, but based on your questions, you have little or no mechanical back ground or experience and I would suggest you take this problem to a good Rover mechanic, not the dealer and have him repair the tranny cooling lines.
taylorm334
Jan 12, 2023 02:06 PM
Athana
Jun 8, 2019 10:23 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
rgrizzard
Mar 6, 2008 10:16 AM
