Engine & Internal Chat about beefing up your engine's insides here.
Transmission fluid change
Old Aug 14, 2011 | 11:48 AM
DiscovermeNOW's Avatar
Default Transmission fluid change
Okay, so I've been mildy informed that if I need to add or change out the fluid in my 2003 Disco2 4.6L I can do it myself. The dealership told me they need to do it, but other have said otherwise.
Is there a "step by step" process anyone has for me? Or any info at all?
Thanks
Old Aug 14, 2011 | 06:09 PM
Check the technical section of the forum under discovery 1 or discovery II for a write up with photos; also download the tech manual called the RAVE, which covers a broad range of Rovers and is the factory manual. Biggest issue is dropping the pan to change the filter. But the photos will help you decide if you want to tackle it.
Athana
Jun 8, 2019 10:23 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
dalfier
Jun 21, 2007 01:45 AM
jmang
Oct 17, 2006 06:58 PM
