Freelander Talk about the Land Rover Freelander within.
shaw0623
Old Dec 29, 2011 | 07:26 AM
shaw0623's Avatar
Default shaw0623
freelander has intermittent fault will not start then after a day will start and run ok then will not start again its a 2003 petrol and the battery is ok any one got any ideas Ps local garage checked it out and could not find any faults
Old Jan 3, 2012 | 10:44 PM
Rovin4life's Avatar
is it a hot start issue, if it is then take out the cam sensor and spray it down with brake clean to see if it restarts.
But if it won't turn over then look at the starter connection, you will probably have to replace the starter. there is a bulletin about it. Had one like that.
