Freelander Talk about the Land Rover Freelander within.
04 Freelander timing disturbed
Old Dec 1, 2011 | 08:55 AM
mississippimech's Avatar
4th Gear
Default 04 Freelander timing disturbed
Please any body; i am installing a new timing belt on my buddys 04 freelander Ln 2.5L v-6; unfortunately prior to calling me he decided to play with the crank i.e timing disturbed!! factory manual says to set crank to "safe" position, then set cam timing, great, all done correctly. manual then goes on to insruct me to insert flexplate locking pin into the flexplate, great, problem is holes don't align!! at this point am i supposed to rotate crank to allow for pin insertion. then install the timing belt???? as it is now, timing CLEARLY not right, when attempting start, air blowing OUT of the intake!!
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
mr_boondoggle
Freelander
Apr 14, 2009 01:11 PM
sky2you
Jan 27, 2009 11:13 AM
sky2you
Jan 25, 2009 11:42 AM
