Freelander Talk about the Land Rover Freelander within.
Sunroof motor
Old May 8, 2010 | 04:40 PM
mlelah's Avatar
8th Gear
Default Sunroof motor
My 2004 freelander sunroof motor is very sluggish. But works fine to tip the glass, but very sluggish when moving the whole glass back. I'm afraid it wont return.
1. Is the problem likely the motor, or is there something else that might be resisting?
2. If the motor, where can I get one?
3. Does anyone have instructions for replacing the motor? Need to take off the headline?
Thanks.
Old May 10, 2010 | 08:45 PM
roverguy7's Avatar
usually its not the motor, or at least the motor. most common failure on those sunroofs is the guides, the part that the glass slides on, these get warpped and cause it to bind as it moves backwards. headliner and sunroof need to come out to replace them
Old May 11, 2010 | 02:36 PM
TurkeyVegas's Avatar
Unplug the fuse its not worth the money to fix as new guides from the stealership will be over 400 bucks for a new regulator
Old May 11, 2010 | 09:20 PM
mlelah's Avatar
8th Gear
OK, thanks. I'll just use the moonroof which works fine. But if I use the sunroof and the motor gets stuck, is there a manual way to return the glass and close the roof?
Old May 11, 2010 | 10:03 PM
roverguy7's Avatar
there is a manual way to close it, however this is only useful when it is unable to close itself, ie the motor doesnt work. if the motor is functional but it wont close, its because its jammed, and you will not be able to override it without breaking it. use it very sparingly until its fixed.
Old May 12, 2010 | 05:20 AM
samejone's Avatar
Hello i am new user for this site. I have a 99 grand am whitch has a bunch of window problems first the window motor on the driver side quit working then the passenger side quit a month and a half later Thanks for ths
Old Sep 3, 2011 | 03:02 PM
jettowski's Avatar
Default Replaced Sunroof motor
The sunroof on my 2004 Discovery stopped working. First pounded it because in the South, it sometimes get hot and sticks. Didn't work this time. Removed panel and hooked back roof switch to front but didn't work. That left either ECU or motor. I picked the motor because the back sunroof worked and I don't use the back as much as the front. Called dealer -- wanted $495 for new motor! Went online found a '99 Discovery motor for $49. Plugged it in -- it worked. Beat the dealership system again.
davidlafrance
Dec 20, 2010 07:22 PM
BigRed98
Jun 21, 2010 12:30 AM
ryant06
Mar 28, 2008 09:01 PM
alanroberts50
Nov 18, 2007 11:56 AM
lrd99
Jul 18, 2007 08:18 PM
