Freelander Talk about the Land Rover Freelander within.
steel water pipes.
Old Jan 13, 2011 | 02:23 AM
lentec's Avatar
3rd Gear
Default steel water pipes.
hi.
my 1999 2.0l rover diesel freelander has just lost all its coolant!! (what a suprise!!). I have found two small holes in the steel water pipes that run over the gearbox. Does anyone know if you can buy these as a pattern part, or is it down to the main stealer for a ridiculous quote!!
i also thought of repalcing them with copper... has anyone done this before and succeeded (or failed)?
thanks
chris
Old Jan 14, 2011 | 01:02 AM
lentec's Avatar
3rd Gear
i went ahead and made them out of copper. all seems to be working fine so far. ill keep you posted of any problems but at least i wont be suffering from rusty pipes again!!
also to make it easier to make and fit the new pipes i removed the inlet and exhaust manifold( with turbo attached). this made bending and checking the pipes much easier!!
Camtait95
May 26, 2014 09:48 PM
kpl1228
Nov 20, 2010 11:05 PM
aiden
Nov 8, 2009 08:41 PM
dmuller
Freelander
Mar 28, 2009 04:11 PM
madmax
Jul 8, 2007 05:54 PM
