ACE suspension pipes
Old Jul 5, 2007 | 04:51 PM
madmax's Avatar
5th Gear
Default ACE suspension pipes
Hi there one and all.
Advice required, I appear to have a leak from 1 or more of the front ace pipes around the f/o/s wheel arch area. Is this something I can tackle at home or is it a garage only repair.
Any help appreciated.
regards
Martyn
Old Jul 6, 2007 | 09:43 AM
Default RE: ACE suspension pipes
Send me your tele number and a good time for me to call you and I'll try and answer your question.
Mike
mikeljacobs@comcast.net
Old Jul 8, 2007 | 04:13 PM
madmax's Avatar
5th Gear
Hi Mike,
Thank you for your reply, but as we are on opposite sides of the pond, would this be a problem, I think we'll have around a 5hr time difference. If it's easier to type let me know what info you need from me and I'll get right on it.
Thanks again for your reply.
Regards, Martyn
Old Jul 8, 2007 | 05:54 PM
I ould clean off the oil fittings with brake or carb cleaner, run the system and then see exactly where it is leaking from, You might be lucky and only need to tighten the fittings. If you have to replace the hose, you could do that then you will need to bleed the air from the system.
Mike
Tin_Man
Apr 12, 2014 11:12 AM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
dmuller
Freelander
Mar 28, 2009 04:11 PM
alrd
Nov 17, 2006 11:25 AM
