Freelander Talk about the Land Rover Freelander within.
Rear Differential dry ?
Old Apr 2, 2009 | 07:18 PM
TurkeyVegas's Avatar
Thumbs down Rear Differential dry ?
Driving home yesterday I could hear the rear end starting to whine louder then normal then suddenly a bearing spun out and the noise was real loud.
I limped home and checked the oil level in the rear diff but it was dry
Now the question is should I try to put a new pinion bearing in it or look for a used rear differential
Old Apr 2, 2009 | 10:11 PM
roverguy7's Avatar
id look for a used one, if you ran it dry for long enough to toss a bearing, theres probably more damage then you see
Old Apr 4, 2009 | 09:08 AM
Default found one
got a diff and now have to install what should I look out for and is it a hard job to do?
Old Apr 4, 2009 | 10:58 AM
roverguy7's Avatar
it needs to be aligned correctly. there is a special tool, a jig that holds the diff, that the dealer has. you should also check all your mounts for the diff, they go bad occasionally, make sure the rubber isnt cracked. if it is, replace that mount, and also replace the lower engine stabilizer bushing
Old Apr 15, 2009 | 01:57 PM
Found a used differential from wreckers with 70k on it 05 same gear ratio came with mounts works good again 320k on the body
Old Apr 15, 2009 | 02:07 PM
also wanted to say that the pinion bearing went out and found alot of wear on the gears with chipped teeth, engine change at 200k tranny change at 300k and I clear a lot of codes still drives mint.
DiscoBenjamin
Aug 3, 2011 07:04 PM
jeffh
May 30, 2011 09:37 AM
timdunbar
Sep 24, 2010 04:55 PM
wynhd
Feb 1, 2010 03:29 PM
tornado_735
Apr 24, 2009 07:33 PM
