Freelander Talk about the Land Rover Freelander within.
heater blower
Old Jul 28, 2011 | 01:26 PM
rabid's Avatar
Default heater blower
i have an 02 freelander
the problem started last week ..driving along the fan started to slow down and eventually stopped all together
i checked both fuses and ok
there is power going to fan
i removed the fan and let it sit out for a day cleaned with an air shot
put back in and it ran for about 10 seconds and slowly slowed to stop ..
any thoughts ideas please its 95degrees here in NYC
Old Jul 29, 2011 | 07:42 AM
rabid's Avatar
do the bump
Old Jul 31, 2011 | 06:16 AM
BritishByProxy's Avatar
8th Gear
Second hand blowers are cheap, and take about 5 minutes to install. Had to do mine this weekend. Three screws, pull it out, put the new one in. Easy fix.
Old Jul 31, 2011 | 01:47 PM
Rovin4life's Avatar
Easy, no reason being is the fan goes because of a coolant leak in the heater core. if their is coolant on the fan then you need to pull the dash board and install a new heater core and fan.
Old Jul 31, 2011 | 05:44 PM
8th Gear
My appologies to all,
My heater core had already been fixed, and the motor was all that remained to complete the job. As a leak hadn't been mentioned by Rabid, I assumed this issue had already been addressed in his vehicle as well. Of course, a leaky heater would need to be corrected before replacing the motor. Fix the cause, not the symptom, right?
Old Aug 1, 2011 | 09:23 AM
rabid's Avatar
Default my fix
i took the blower out again and gave it a wd 40 bath left it for a few hours and then dried with compressed air .replaced it and its up and running good as new ....? dried gunk from the heater core maybe ?
Old Aug 5, 2011 | 10:18 AM
rabid's Avatar
Default fan blower
so i got the fan working better than ever ...3 days no problems
then i was crossing the williamsburg bridge stuck in traffic and i hear the fan slowing down and eventually stopping ..all speeds for about 30 minutes ..all fuses ok
is the fan over heating / over working
i am in NYC its 95 degrees and most of my driving is bumper to bumper 20 miles an hour ?
mattrickman
Aug 17, 2008 06:55 AM
Paul Schmitz
Jun 18, 2008 05:20 PM
jooknon
Jan 9, 2008 11:19 PM
newf4us
Freelander
Nov 5, 2007 06:59 PM
alpinab7
Nov 29, 2006 11:27 AM
