Freelander Talk about the Land Rover Freelander within.
IRD or Rear Diff?
Old Jul 26, 2010 | 12:37 PM
TurkeyVegas's Avatar
Default IRD or Rear Diff?
My freelander just started thumping and clunking worse when turning but I cannot pin point it sometimes it sounds like its comming from the front end but other times the rear end
Its so bad I cannot drive it on the road how can I tell if the half shaft are cooked it might be these ???????
Old Jul 26, 2010 | 08:48 PM
You need to have all the driveline fluids changed TODAY and hope it is not to late.
There is a fluid couple in the middle of the car that transfers power from front axle to rear axle as you drive.
Old Jul 31, 2010 | 07:38 PM
Rovin4life's Avatar
If it clunks you can check the rear diff bushing. its near the driveshaft. Many of those break around the bolt. But its possible you also have a loose sway bar link or something else in the front suspension. Have the vehicle put on the lift and inspected.
Old Aug 1, 2010 | 10:23 AM
Its the IRD unit so I just picked one up at the wreakers for 350 I might have to check the drive shaft now to see if that VCU failed
Im now drivin with FWD I took the drive shaft out
Old Aug 1, 2010 | 10:25 AM
How do I find out if the VCU has failed ? its out of the truck right now
Dale Lloyd
Freelander
May 2, 2013 04:08 PM
Freelander2001
Freelander
May 9, 2012 07:40 AM
JamesChristo
Freelander
Jan 7, 2012 11:29 AM
JamesChristo
Jan 5, 2012 09:40 PM
Marcoadieter
Sep 26, 2010 10:36 PM
