Sponsored by: CARiD
Service indicator
Old Aug 3, 2011 | 07:15 PM
fsufan's Avatar
4wd High
Question Service indicator
I have an 08 LR2. Doing my oil change. Is there a way to reset the service indicator like you can on some american models? can anyone help!
Old Aug 4, 2011 | 01:02 AM
socalrovershop's Avatar
turn key on position 2 at the same time holding the reset button on the ipak. when it starts blinking let it go then it will say time. hold for couple seconds till it says reset then press it again it will say date hold it again till it says reset then its all done
Old Aug 5, 2011 | 11:15 AM
fsufan's Avatar
4wd High
Default service indicator
My lr2 key does not turn so im not clear what you mean when you say turn key on position 2
Old Aug 5, 2011 | 06:15 PM
Seriously?
Put the key in the ignition.
That is position "0"
Turn the key forward one click, that is position "1"
Turn the key one more click, that is position "2", also known as the "run" position, that is the position the key is in after you start the engine and let go of the key.
The next position is the "start" position.
Old Aug 6, 2011 | 04:10 PM
Adigorn's Avatar
turn on the key means press the start button without pressing the clutch/brake so all the lights will be on and engine will not start turn off the key pres the start button again so lights will be off
hope that helps
Old Aug 10, 2011 | 03:26 AM
fsufan's Avatar
4wd High
you have to understand that a LR2 has the push button start.
Old Aug 10, 2011 | 03:29 AM
fsufan's Avatar
4wd High
Cool Finally
Yes that helped, thanks to everyone for the advice. I ended up taking it to a oil change place because i dont have the filter wrench. But I will order one soon. They could not reset the service indicator but with all your help I did it at home.
Old Aug 10, 2011 | 04:19 PM
you could use a 36mm 1/2 socket and extension
Old Oct 27, 2011 | 10:50 AM
Rogerb's Avatar
Angry Service reset message
On 2011 models you can not reset the service warning light/message, you are forced to take it to a main dealer, this is a disgrace on the part of Landrover and I think is illegal trading. After owning three Landrovers from new this is my last one after this behaviour.
Old Oct 27, 2011 | 01:25 PM
for lr2 you can still reset it
