Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 01-15-2012, 02:42 PM
Junior Member
Default 2006 Range rover HSE tranny help
Hi, I have an 06 Supercharged HSE that is leaking tranny fluid from the oil pan gasket area.
is there a How to guide for an 06 tranny service?
Old 01-16-2012, 02:25 AM
Senior Member
pretty easy to do if your talking about the full size range rover not the sport. you have several torque srews that you remove and thats about it. but in my own opinion i would also replace the electrical sleeve connector wich always leaks and thats probably where its leaking now. make sure to either get new fluid or at least save the old fluid to put it back into the transmission
Old 01-16-2012, 12:12 PM
Junior Member
Quote:
I removed the oil pan but could not locate the electrical sleeve. And the fill plug is the one u need an allen wrench to remove correct
Tags
06, 2006, adapter, changing, connector, fluid, hse, land, pan, plug, range, rover, service, sleeve, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
