Sponsored by: CARiD
2006 Range rover HSE tranny help
Old Jan 15, 2012 | 02:42 PM
Chrpin Vett's Avatar
3rd Gear
Default 2006 Range rover HSE tranny help
Hi, I have an 06 Supercharged HSE that is leaking tranny fluid from the oil pan gasket area.
is there a How to guide for an 06 tranny service?
Old Jan 16, 2012 | 02:25 AM
socalrovershop's Avatar
pretty easy to do if your talking about the full size range rover not the sport. you have several torque srews that you remove and thats about it. but in my own opinion i would also replace the electrical sleeve connector wich always leaks and thats probably where its leaking now. make sure to either get new fluid or at least save the old fluid to put it back into the transmission
Old Jan 16, 2012 | 12:12 PM
3rd Gear
I removed the oil pan but could not locate the electrical sleeve. And the fill plug is the one u need an allen wrench to remove correct
Chrpin Vett
Jan 15, 2012 02:38 PM
SuperchargedV8
Oct 27, 2011 12:19 PM
MagnaflowRep
Headers, Intake, & Exhaust
Sep 2, 2009 12:26 PM
AmexBlackG5
Jun 25, 2008 01:04 PM
