Sponsored by: CARiD
No Intermittent Wipe in Freelander 02 plate
Old Oct 12, 2011 | 03:13 PM
chelbb's Avatar
Default No Intermittent Wipe in Freelander 02 plate
Hi all
Just bought an 02 plate freelander and everything is great except the intermittent wipe wont work! Normal wipe and the one wipe work fine and the wipers park properly everytime. Can hear the click when intermittent is selected but nothing else happens. Hubby has tried fuses, connections, etc, no joy. He isnt sure which is the correct relay as that is next thing to try unless anyone has an answer to this prob! Living in England where its damp and drizzly the intermittent wiper is a must!!
Chel
Old Oct 12, 2011 | 03:38 PM
Looks like it will be the switch, the fuses in play are # 3 and # 8, but they control more than the "flick wipe".
Attached are drawing and switch photo. Outside chance it could be a wire on the actual connector.
You can download the whole set of tech manuals and owners manuals, called the RAVE, for free at link below. Stands for Rovers Are Very Economical.
This forum while international, is also US based, there are also very good forums in the UK.
File Type: pdf
File Type: pdf
Old Oct 15, 2011 | 12:20 PM
chelbb's Avatar
Thank you, will get hubby to check
StillRoven
Mar 6, 2025 09:37 PM
Grizzul114
Freelander
Feb 27, 2014 10:56 PM
Discolife
Jan 9, 2013 04:04 PM
wisconsinoverlander
Oct 26, 2012 07:46 PM
Seven Lucky Logs
Sep 19, 2006 07:25 AM
