Sponsored by: CARiD
Flush attachment for metal radiators with pix
Old Sep 15, 2011 | 09:53 PM
Default Flush attachment for metal radiators with pix
See pix for adapter from plumbing aisle, and yes, it is 1/2 inch NPT, so there is some leakage, and you can bugger up threads if you are not careful. Two adapters used to make this up.
They also have these "rubber bladder" drain cleaners, that attach to the end of the garden hose, then swell up slightly and spray water out the end as well. Does not move a lot of volume. If using on an outlet or inlet radiator tube, would be a good idea to put a couple of hose clamps around the soft metal tube to prevent distortion.
Attached Thumbnails Flush attachment for metal radiators with pix-p1120238.jpg
Old Sep 16, 2011 | 07:20 AM
antichrist's Avatar
I've been using these since the 70's, they work quite well.
Prestone® Flush N Fill Kit | Print View | Products | Prestone®
You do want to remove the block drains when done and then run a cycle of distilled water through before refilling with coolant.
Jon Pitts
Jan 19, 2015 12:04 PM
roverwoody
Feb 10, 2014 10:39 PM
Savannah Buzz
Nov 15, 2012 09:59 AM
Savannah Buzz
Off Topic
Jul 28, 2011 04:42 AM
adambarry
Mar 30, 2010 08:17 AM
