Ignition Timing
Old 01-25-2008, 09:40 AM
tico21's Avatar
5th Gear
Default Ignition Timing
I have a 86 range rover classic with a 3.5lt fuel injected.
I have not been able to time it correctly. The timing is way off. I have lined up the distributor according to workshop manual turning the distributor will not allow me to set the initial timing. its way off 50+ degrees.
I have check air gap, done tune-up all the works but the timing is killing me.
Thanks for the help
Old 01-25-2008, 08:04 PM
lrobin3w's Avatar
Default RE: Ignition Timing
I would double check your timing set up. remove #1 sparkplug, rotate crankshaft untill the TDC mark on the front crank pulley lines up with the pointer. #1 piston should be at the top of its stroke, now ensure that the dist rotor is pointing near the #1 terminal on the cap. If its not close you will have to re-index the distributor untill it is. then you should be able to set the timing. Hope this helps.
Old 01-25-2008, 11:58 PM
tico21's Avatar
5th Gear
Thanks lrobin!
This did help. My car seems to stutter between about 1500 - 2200 rpm. At full throttle it evens out.
Could this be the TPS or still a timing issue?
Thanks
A5scott
07-11-2015 07:25 PM
Martin Rodriguez
02-25-2014 08:55 PM
cranky
05-30-2010 07:51 PM
tophur
02-06-2008 07:19 PM
chelo
03-23-2006 04:39 PM
Quick Reply: Ignition Timing
