Sponsored by: CARiD
pulling codes P0340, P0579, P0345, P0489
Old Nov 24, 2011 | 03:48 PM
Ricki Landers's Avatar
Default pulling codes P0340, P0579, P0345, P0489
My 06 LR3 is pulling the following codes P0340, P0579, P0345, P0489, it had been hesitating when driving up hill prior to today and today it will not start and only makes a clicking sound when you try to turn the engine over. Has anyone else pulled these same codes in conjunction or have any ideas on what to do to fix it?
Thanks in advance
Old Nov 25, 2011 | 07:41 PM
I dont know what those codes mean, but it sounds like a dead battery for starters.
Some cars will throw all kinds of trouble codes when the battery voltage gets to low.
Old Nov 25, 2011 | 08:50 PM
Most of us only land disco codes, i have never come across lr3 codes and wold suggest you do a google search for them. As spike has mentioned, remove your battery and go get it charged first
Old Nov 25, 2011 | 09:10 PM
I had a Oldsmobile that when the battery went bad it spit and sputtered, every warning light on the dash came on (except the battery light) and it threw the check engine light and several codes, then died.
I am just throwing info your way, that may or may not be your problem but worth a check.
brirsl
May 4, 2014 04:23 AM
cgeschwell
Apr 18, 2011 09:34 AM
imaric
Sep 28, 2010 09:04 PM
Outback Jim
Jun 22, 2010 09:14 AM
