Error codes p0300, p0340 and p1300 HELP!
Old Apr 17, 2011 | 07:52 PM
cgeschwell's Avatar
7th Gear
Default Error codes p0300, p0340 and p1300 HELP!
I have a 1999 discoII with 140k miles, getting errors p0300 which states cylinder misfire, randon cylinders. p0340 camposition sensor(which I replaced this morning and p1300 ignition coil primary feedback circuit fault. I'm just wondering if anyone has seen this and can point me in exactly where to go, the rover is sluggish during idle and excelleration, drives ok when up to speed. what could this be? As I said I though it was just the cam position sensor and replaced that and it did little to nothing to help. thanks guys you always point me in the right direction
Old Apr 18, 2011 | 09:34 AM
Have you tested for a signal from the new cam sensor? Look in the Rave CD for testing procedures.
Jeff Arkun
Apr 3, 2013 09:49 AM
fund247
Feb 16, 2013 02:22 PM
ChefGabe
Jan 26, 2013 09:35 PM
lesjonpool
Aug 24, 2011 07:58 PM
