Sponsored by: CARiD
What is this wire? 04 disco
Old Dec 10, 2011 | 01:35 AM
clayton's Avatar
Default What is this wire? 04 disco
Like it says I have an 04 discovery and was under the truck on driver side and noticed an orange female 3 point connector hanging down not connected to anything.
Tried to look it up on rave can't figure out what it is.... If you know please tell me.
C
Old Dec 10, 2011 | 04:26 AM
Where on the driver's side - fore or aft, near what item, and can you make out any color of the wire in the connector other than black?
It may be the connection for the ___________________ . But with a little more info we can run it down. Check engine light on, or does it come on at self test each time cranked? Some sensors will set codes if unplugged, some, like tranny temp, won't.
Old Dec 10, 2011 | 09:56 PM
clayton's Avatar
The wire comes down near the pre cat sensor wire looks black connector is female orange in colour and rounded corners not square more rectangle. Looks to be coming down from engine area
Old Dec 10, 2011 | 10:15 PM
clayton's Avatar
Forgot no engine light on but it works. Have odb computer no codes. Weird huh?? I will say the my vac pump runs longer then usually did
Old Dec 10, 2011 | 10:47 PM
If you go to the RAVE, electrical library part, connector section, it has a color photo and location of every connector. Just click thru, only takes a split second to think that is no where near..
Since no codes, might be one of the sensors that just turns on an idiot light and does not interface with the ECU. Exampes are transmission temp and transfer case over temp.
Sample of these pages attached with an orange connector, rectangular, black over cable, but wires inside are various colors, and the O2 sensor, if unplugged, should set a code.
File Type: pdf
Old Dec 11, 2011 | 09:45 AM
clayton's Avatar
Hmm.. Thanks I did go through rave and nothing looks like it. It's weird maybe I'll take a pic of it
Old Dec 11, 2011 | 10:21 AM
hilltoppersx's Avatar
it could be a few things. ACE, SLS.... what options does your truck have?
Old Dec 11, 2011 | 01:18 PM
Maybe they left out the flux capacitor....
Old Dec 11, 2011 | 10:50 PM
clayton's Avatar
I have a stock se no hydraulics,
Old Dec 11, 2011 | 10:51 PM
clayton's Avatar
It's not hard plastic it's more rubber like
