Surround Camera Problem - No Image Displayed
Old Oct 19, 2011 | 11:14 AM
  #21
Bladzee's Avatar
New to the forum, but I found this thread after researching the same problem. In the past I simply had the blue box limiting which cameras I could use, but in the last two months it has evolved into a warning light that says "Camera System Fault". It's been to the dealer (Encino, CA) twice and is about to go in for a third time today. I believe they replaced the wiring harness last time, so I'll be interested to hear what they have to say this time. Obviously this isn't a catastrophic issue, but my god it's annoying to have to be in and out of the dealership five times this year for electrical issues.
Old Jan 9, 2019 | 04:42 PM
  #22
Chrispiec's Avatar
Originally Posted by mgregorio
I have the same issue on my '10 Range Rover. The funny thing is that, at night, with low luminosity, the camera works perfectly. In other words, it works only at night.
Any ideas ??
did I'd you ever find out the solution? I have the same issue. Camera does not work in daylight but works perfectly when dark.
Old Jun 14, 2020 | 03:58 AM
  #23
Ditschelping's Avatar
Originally Posted by mprsev
Any updates on this issue? I just picked up a 2010 RRS last night with the surround camera feature and the front right camera is not functioning, simply displaying the blue broken-camera icon. I noticed the rear camera also displays the same icon for a brief moment but the picture then comes on and this delay is only when using the surround camera feature and not the reverse feature.
Any help with TSB #s or dealer implemented remedies would be greatly appreciated as I have an appointment with my service department tomorrow.
Thanks in advance!
I have exactly the same problem. My front right camera is showing the camera broken icon and my rear camera is flashing exactly three times (no image, correct image, no image, correct image, no image, correct image) and then the image is working properly.
Does anyone have an idea on how to check what is going wrong?
Thank you?
Old Jun 14, 2020 | 04:13 AM
  #24
After searching a little bit more I found this Bulletin:
https://static.nhtsa.gov/odi/tsbs/20...70349-0699.pdf
The Camera Control Module (LR041416) is about 580€ in germany. But I do not know, if this would really solve the problem.
(https://www.discovery-parts.de/suche.html?term=LR041416)
Anybody an idea how to move on without buying the new part?
Old Mar 19, 2021 | 09:57 AM
  #25
myzippybiz's Avatar
Default Back Up Camera
Hey folks I have a 2007 Range Rover Sport. I love this new toy... Problem is the rear camera does not work. I tried replacing with a new NTSC camera Model YZ208-C that was recommended. Still no camera. I have power to the area 12 volts dc. Any suggestions? Everything else works on touch screen but camera and i guess worth mentioning the dvd and cd does not work either. <Maybe a loose cord or bad lcd unit.
disco5fl
Oct 19, 2023 09:00 PM
gilakinlr4
LR4
May 2, 2020 07:18 PM
James C Everington
LR4
Feb 17, 2018 08:24 PM
avraja
LR4
Apr 19, 2013 12:48 PM
theofam
LR4
Dec 17, 2010 05:37 PM
