Sponsored by: CARiD
What fuse whould it be?
Old Dec 20, 2011 | 10:46 AM
Maurice Carter's Avatar
4th Gear
Default What fuse whould it be?
00 Disco2, the cig lighter,seat heater switch and rear view mirror are all not working (no power). I was told its all connected to the same fuse. Is this true? If it is what fuse or ?? do I need to look at. Thanks..
Old Dec 20, 2011 | 12:47 PM
Fuse Link 7 in underhood fusebox, fuse 15 in passenger compartment fuse box.
Old Dec 20, 2011 | 02:42 PM
You better check your inside fuses under the dash as well as under the seats, cause what you are describing may be multiple fuses.
Seat heater fuse is under each seat.
Old Dec 20, 2011 | 05:41 PM
Attached three pages of circuit diagrams, all to fuse 15 in passenger compartment fuse box under dash. Rear view is called "interior mirror". Certainly a strange mix....
File Type: pdf
File Type: pdf
File Type: pdf
Blakesrover
Feb 21, 2013 01:43 AM
ferrelltodd
Jul 24, 2005 01:22 AM
stealthn
May 23, 2005 01:20 PM
mikemeyer0
Apr 1, 2005 02:03 PM
hecareth
Feb 20, 2005 11:31 PM
